cp-e Ice Box Dual Air Intake for 24-25 Mustang !!
beefcake
Gold Sponsor
Bethel
Custom Performance Engineering Ice Box Dual Air Intake (2024 - 2025 Ford Mustang 5.0L) FDAD00015B
S650 Mustang cp-e Ice Box Dual Air Intake for 24-25 Mustang !! S650MustangIntake-Render1-2ksq__84755.1739380297
S650 Mustang cp-e Ice Box Dual Air Intake for 24-25 Mustang !! S650MustangIntake-Render2__12358.1739380297
The S650 Mustang GT and Dark Horse cars are already fantastic to begin with, but why not make them a bit better than stock? The stock intake system is designed well, but still we felt that we could take the good from the stock system and make it even better. After a long engineering process, we are proud to release the IceBox™ Dual Air Intake for the S650 Mustang GT and Dark Horse.
S650 Intake Features
  • Custom designed airbox using factory ram air
  • Perfect OEM fitment with no CEL
  • No power loss in lower RPMs
  • DFlow™ filters with SynoilD™ coming soon
  • Roto Molded design for smooth size transitions
  • Limited Lifetime Warranty
For this new intake style we opted for a roto molded design produced from XPLE plastic. This type of plastic is very strong and temperature resistant to help keep intake temps down. The airbox is molded to fit directly into the OEM Ram Air ducts in the grille pulling in that fresh cold air to build power. Both clear plexiglass windows are included along with all necessary hardware (ships with orange peel-off protective coating).
S650 Mustang cp-e Ice Box Dual Air Intake for 24-25 Mustang !! S650MustangIntake-Render4
Retains OEM MAF Connection
Part of why the S650 Mustang is so effective and efficient at what it does, are all of the sensors monitoring everything as you drive. The Mass Air Flow Sensor is no different. To properly communicate what is happening in the air inlet to the engine, these sensors are required for the best operation. We made sure that they are retained on our intake and without being an eye sore.
S650 Mustang cp-e Ice Box Dual Air Intake for 24-25 Mustang !! S650MustangIntake-Render3
Smooth Diameter Grade Tubes
The XPLE intake tube passes through the airbox and bolts to the outside wall. The filter is attached to the tube and butted up to the inside of the airbox to create a tighter seal and keep hot air out. The tube has a gradual change from 5" to 3.5" to smoothly compress the air to provide a minimal amount of energy loss which translates to a higher air speed through the tube. We include a 5” air filter specially designed to give the most, free flowing air flow possible. This system comes with a DFlow™ Intake Filter, but we will have the option of the SynoilD™ in the near future.
S650 Intake Construction
Part of what makes the stock intake system well-rounded is the great design of the stock box. It brings in cool air efficiently and isolates the filter from the hot air in the engine bay. Where the stock box is a bit lack-luster is where the cp-e® IceBox™ Intake shines. The intake boxes and tubes are roto molded from XPLE plastic. XPLE is great for this application for not only because it cannot corrode, but also its thermal properties allow the interior of the boxes to stay cool, even when the boxes themselves heat up. The boxes utilize both stock fresh air ducts to grab cold air. The box is topped off by clear plexiglass to seal the filter from the heat, providing a sweet view and easy access to the filter for cleaning and replacement. Lastly, the box easily mounts in the stock location with the laser cut brackets and CNC-lathed mounting feet.
