Fresh Stock of Steeda Autosports here at Lethal Performance!!
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Hey, All!
We’re starting off the New Year with a fresh stocking of Steeda Autosports components and kits for the Mustang!
S650 Mustang Fresh Stock of Steeda Autosports here at Lethal Performance!! steeda in stock jan 2024
Check out some of the fresh stock below!
Steeda ‘Stop the Hop’ Street Starter Kit (2015-2024 Mustang) - 555-4455
S650 Mustang Fresh Stock of Steeda Autosports here at Lethal Performance!! stopthehop__93436.1681300017
The Stop the Hop Starter Kit is the perfect start for those who want to eliminate wheel hop while also staying on budget. Each component of this kit is designed to eliminate wheel hop and subframe movement while not increasing NVH, is a simple install procedure, and requires no permanent modifications.
Includes:
  • Steeda’s IRS Subframe Support Braces
  • Steeda’s IRS Subframe Bushing Support System
  • Steeda’s IRS Subframe Alignment Kit
We installed this exact kit on our 2024 Mustang GT, along side some other Steeda goodies. Check out the full write-up here! - https://www.lethalperformance.com/info/steeda-stop-the-hop-for-the-2024-mustang
S650 Mustang Fresh Stock of Steeda Autosports here at Lethal Performance!! 2024mustang_steedasuspension
Check it out here! https://www.lethalperformance.com/s...t-starter-kit-2015-2024-mustang-555-4455.html
Steeda Clutch Spring Assist and Spring Perch Kit (2015-2024 Mustang) - 555-7027
S650 Mustang Fresh Stock of Steeda Autosports here at Lethal Performance!! steeda-mustang-clutch-spring-ass
Looking for more pedal feel for better engagement? Look no further! The 2015+ Mustang GT comes with a 185 lb/in clutch assist spring installed from the factory. This high-rate spring is what causes such a vague and disconnected clutch pedal feel. When swapped out with Steeda’s 35 lb/in
Clutch Spring Assist, you’ll get a HUGE improvement with a consistent spring rate and more linear clutch feel.Additional Features
  • Heavy Duty design that’s guaranteed for life
  • Avoid slave cylinder damage due to removal of stock clutch spring
  • 100% Made in the USA, in house in Valdosta GA
Check it out here! https://www.lethalperformance.com/s...ing-perch-kit-2015-2023-mustang-555-7027.html
Steeda MT-82 Transmission Mount Bushing Insert (2011-2024 Mustangs) - 555-4037
S650 Mustang Fresh Stock of Steeda Autosports here at Lethal Performance!! steeda-mt-82-transmission-mount (1)
Steeda’s polyurethane Mount Bushing helps reduces transmission movement, help keeping the shifter aligned with the transmission, and therefore reducing the chance of missed shifts. It is easily able to be removed and reinstalled for your convenience.
Grab yours here!
https://www.lethalperformance.com/s...shing-insert-2011-2022-mustangs-555-4037.html
Check out everything Steeda here!
https://www.lethalperformance.com/search/?q=Steeda
As always, if you have any questions or need some help in finding your Steeda mods, reach out with anyone of us here at Lethal Performance!
