I'm already moodding the S650
lisandra
mama smurf
Puerto Rico
ecoboost PP non premium
SO...the racer looks amazing as F. Aside from the obvious wide treatment (which i dont care for), Do you think its the same bumper with the plastic scoop things on the bottom vents ripped out? cause if so this is my first mod day 1!
S650 Mustang I'm already moodding the S650 ford-mustang-gt-2024-02-exterior-front-scaled
S650 Mustang I'm already moodding the S650 pgnopzxji4qng9qdz68h
SmokinAces
San Antonio
2020 GT350
Hey @lisandra , sure does look like the the bottom outside vents have the black trim pieces removed. The head lites well, if you put a very dark smoked clear strip under the tri lamps you could get the same effect. Not sure what to do about the grill thou, but for sure it will need to be changed. I’m all over that Supercar grille!!
lisandra
lisandra
mama smurf
Puerto Rico
Hey @lisandra , sure does look like the the bottom outside vents have the black trim pieces removed. The headlamps well, if you put a very dark smoked clear strip under the tri lamps you could get the same effect. Not sure what to do about the grill thou, but for sure it will need to be changed. I’m all over that Supercar grille!!
I think the headlamps just have a dark film over them to look like this, like the smoke kits for the s550. I brightened up the image and that is certainly a GT grill but in carbon fiber. It should be easy to duplicate this look
S650 Mustang I'm already moodding the S650 pgnopzxji4qng9qdz68h copy
SmokinAces
San Antonio
2020 GT350
Wow good job. Didn’t realize it looks the same but made out of dry carbon. I’m sure the after market will be all over themselves coming up with different possibilities. This definitely has me excited.
