SS3 Add-On Fog Light Kit | GT + EcoBoost | Diode Dynamics
Diode Dynamics
St. Louis, MO
www.diodedynamics.com
2015 Mustang EcoBoost
Introducing our new add-on Stage Series Fog Light Kit for the 2024 Ford Mustang! This kit allows you to mount two SAE-compliant fog lamps in the factory bumper while maintaining an OEM appearance thanks to the custom-designed, vehicle-specific bezels.
Aggressive Appearance Our team of in-house engineers have designed two unique bezels to fit perfectly into the factory bumper of the GT and EcoBoost trim levels without any cutting or modification to the factory bumper. These bezels retain the unique styling of the OEM grilles, while the included SS3 LED pods provide a more aggressive appearance. For GT owners, we've kept performance in mind, ensuring the bezel allows for adequate airflow to the cooling system. With a truly unique design, this add-on fog light kit is sure to make your S650 Mustang stand out on the road.
Factory-like Operation. Unlike other basic harnesses on the market, the Add-On Fog Harness included in this kit allows the fog lights to operate automatically, just like you'd expect from the factory. By using our vehicle-specific harness, the backlight will come on with the parking lights, and the main beam will operate just as a factory fog light, turning on with the low beams and turning off with the high beams. This is much more convenient than manually flipping a switch on every time you want to use them!
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in the SS3 collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency. Click here to learn more: Total Internal Reflection (TIR) Optics | Stage Series Video.
From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the SS3 serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the SS3 is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
SAE Compliant. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
SAE Fog uses our distinctive FineLine optic design, and provides an extremely wide field of view, with high-intensity output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of cool white or yellow, which is often said to help cut through inclement weather.
Sport, Pro, or Max. Stage Series LED pods are available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses high-intensity LEDs, and is the best bang for the buck you’ll find. The Pro model steps things up in a big way, with double the total power. Finally, the Max model is designed with cutting-edge automotive emitters, for both high power and extreme intensity. This brand new technology comes at a cost, but if you’re looking for the absolute best in lighting performance, the SS3 Max is the answer.
White or Yellow. The Elite Series Fog Lamps in this kit are available in a cool white or selective yellow output color.
The white is a 6000K color temperature, which is a true cool white output. This will perfectly match other LEDs on your vehicle, such as DRLs or running lights. The white option also offers a premium BMW-style color band at the very top of the beam pattern.
The selective yellow option is 3000K in color temperature, which is great for high contrast in inclement weather, or in providing a distinctive look on the road. The yellow lamp consists of a yellow multi-die LED emitter paired with a yellow-tinted lens, to provide unmatched output and optical efficiency, even with the intense yellow output.
Backlight Functionality. All Elite Series Fog Lamps come standard with an integrated amber accent light. This backlight feature fully illuminates the main lens with amber LEDs, intended to match other position, sidemarker, or corner lights on your vehicle. Check local laws and regulations for acceptable use.
Bolt-On Fitment. The brackets included with the lamps bolt directly to the back of the provided bezels. With built-in adjustment, the EcoBoost kit can be aimed after installation. A custom aiming tool is included with the GT kit to preset aiming prior to installation. Our add-on foglight wiring harness is included to connect the fog lights to your factory lighting functions. Click here to learn how to aim your Elite Series Foglamps: How to Aim Your Fog Lights.
NOTE: This kit is NOT compatible with the Dark Horse trim level.
In the Box:
  • Two (2) Elite Series Type A Fog Lamps
  • Two (2) Vehicle specific Fog Lamp Bezels
  • One (1) Add-On Fog Harness
  • One (1) Fog Lamp Aiming Tool (GT only)
  • Four (4) Zip ties
  • Two (2) T-taps
  • Hardware Kit
2024+ S650 Mustang GT Installation:
2024+ S650 Mustang EcoBoost Installation:
Assembled with Quality - in the USA. Elite Series Fog Lamps are assembled in the USA using OEM-grade materials, including a precision aluminum casting, UV-coated outer lens, copper-core circuit board, and multi-die automotive emitters. After being assembled by Diode Dynamics in St. Louis, Missouri, they are robotically sealed with urethane epoxy for long-lasting protection against moisture, and packaged in form-fit foam for safe transportation. No expense has been spared, from materials to assembly, right here in America.
Proven Reliability - Backed for 8 Years. Like our popular Stage Series lineup, Elite Series LED lamps have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components on your vehicle. With integrated moisture-proof vents, the lamps can “breath” with changes in temperature, maintaining a strong seal over time. And with built-in circuit protection for voltage spikes and reverse polarity, these lights will keep working for years. They are backed by an industry-leading 8-year limited warranty.
Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly assemble and engineer our own products in the United States, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project!
Questions/Concerns:
Hours:
Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Forum Member Benefit: All forum members are eligible for a free US shipping code. Please send us a direct message for the exclusive code and save on any new or future order.
John C.
Diode Dynamics
Social Media Community Manager
