Adamrx11
- Thread starter
- #1
Went out this morning at 6am 70 degrees and all tires showing 30 psi, a quick lap around the block and up to 32psi. Question is do I need to put some air in them to walk out to 32psi cold? The temp fluctuates crazy here, by 10am it's 90 degrees and then I walk out to 32psi at that time, so just wandering how you guys handle the temp and tire psi fluctuations. Also wandering if the pulling (and this is before spirited driving, just cruising in normal) I'm feeling in the morning is the oil needing to warm up or is it the tires being "low" any insights are appreciated!
