Farmer Fran
Again, I will be corrected but I am pretty sure my 355 is no Torsen, just normal 355 LSDthe difference is not only the gear ratio when you order the 3.55 option, it is a completely different limited slip system, clutches vs Torsen
That is why it is a $1000+ option for the 3.55 on the order sheet
If you have a 3.15 LSD in your mustang, the parts, meaning a 3.55 whole center section ready to drop in ( M-4001-88355B ) from @LevittownFordParts is under $1200 plus fluids.
The gears and install kit to swap out your existing gears will run you just shy of $500 and someone who can press bearings on and get the shim packs right for the proper gear meshing.
Just check the driveshaft flange as there are differences between stick and 10 speed cars
Plus you need to recalibrate the speedo for the new gear ratio, and maybe the transmission shift points
Personally I have never found myself wanting for the 3.55 the 3.15's work lust fine for me
