clunking/small knocking when light braking
Adautomotive
Belgium
Dark Horse
I'm trying to nail down the source of the noise myself before going to dealer. Does yours sound likes it's coming from back of car ? Mine makes sound repeatedly when backing up and braking, then going forward. Keep us informed on grease, dimensions and parts replaced.
@Cobrakit it was the same for me noise from rear right then i thought it was right front etc. The best to replicate the noise "for me" was turn the wheel to right
I've put about 200 miles on the DH since the grease was applied and haven't heard the clunk/pop. I'm still waiting on a new Output Shaft Flange to arrive at the dealer. It's currently on backorder. Once it arrives I will have them remove the original and replace with the new one. We will also check and see how much grease is still in there.
I'm considering taking a pair of calipers to measure the major and minor diameters on the spline shaft and output shaft flange. I'll compare the spline dimensions on the original flange and the new one to see if the fit is tighter than OEM.
I noticed the extensieve play without grease. If you remove the 15mm bolt and slide it over the spines and gently twist from left to right you feel it immidatly. When i removed it you could see in the back of the hub spline wear. The 15mm bolt came lose like it was just hand tight even there was red loctite on it. My opinion is when we put grease on it dampens the play plus when you put it back it goes not in the same splines wich eliminates the play further. Mine arrives today i Will take some pictures from the New and old one.
Xiaoqian
China
DarkHorse
@Xiaoqian thx man!!! I can conform the fix today 200% I removed the output flange today and indeed not one bit of grease mine looked the same build in januari 2024. I even had some play on the splines after cleaning and put ceramic grease on the splines retorque everything no more play! And guess what first drive today without clunck only the exhaust! Going to order a New one too just to be safe because of the play on the splines. I will post some photo's of the proces after the New part arrives because i could clearly see where the wear was. Thx man!
My pleasure to help everyone in here. It was indeed very difficult to spot where the noise came from. Fortunately the mechanics helped me solve the problem and I would really like to share it with everyone in the world who has the same issue, because I know this car is pretty rare and I also know how irritating the noise can be.
RaceRedder
Houston, TX
Dark Horse HP
I'm not mechanical, but how difficult is it for a mechanic to change this part? How deep is it hidden in the car? Is it easy to reach?
Adautomotive
Belgium
Dark Horse
Litteraly 15min job. 4 bolts driveshaft put driveshaft a little aside and one bolt from flange. And that's it. No heatshield or other parts need to be removed.
Adautomotive
Belgium
Dark Horse
CoolMonkey
Hungary
Mustang DH
Unfortunately it didn't fix my problem so the dealer is changing the driveshaft now. On the side note they broke my front splitter when they lifted the car...
brandonxDH
texas
2024 Mustang Dark Horse
hello all, fellow 2024 mustang dark horse owner here. i have been dealing with this issue as well for about a month now. Took my car to a dealer 3 times and every single time they sent me back with the car not being fixed. The noise has been consistent and even when showing the techs there at the dealer they specifically told me, “If it gets worse bring it back.” ... Anyways, they claimed it was my lowering springs making the noise. Took them out and put back the stock ones, guess what? Still making the noise. I can say for the time it’s been doing this it has not effected performance at all. So i’m in a pickle of annoyance at the moment.
If anyone has figured this out please let me know, tired of dealing with these dealers.
Adautomotive
Belgium
Dark Horse
And what exactly didn't fix your problem?
They removed it? Put grease on? Replaced the flange? What did they do?
HMBSTNG
MN
2024 Mustang GT PP 10r80
Can someone share the torque specs? I just discovered this issue recently and want to try this out myself first. Thanks
HMBSTNG
MN
Do you have the torque specs? Also, after removing the driveshaft to the side, remove the single flange nut and it just slides out? Do I need a pulley removal tool?
Also, What socket size are needed?
Thank you so much!
5.DREW
5.DREW
New York
I’ll be doing this to mine as well, please if anyone can provide the torque specs and what kind of grease to use I’d truly appreciate it
HMBSTNG
MN
All bolts are 81#. Make sure you use orange locktite
Used Valvoline Moly-Fortified Gray Full Synthetic Grease, 1 Pound. Got it from Advance Auto
S650 Mustang clunking/small knocking when light braking 71J1XLRRyIL._AC_SL1500_
HMBSTNG
MN
One a side note; my issue wasn't even this. It end up being a bad wheel bearing passenger rear that was making that clunking sound. Ford warranty
Also, my shaft was bone dry. I lubed it with the above grease and nothing changed. I had ZERO play before and after.
