Dark Horse Handling Pack offset on wheels?
Project6GR Wheels
Los Angeles, CA
Shelby GT350R
hey so i ended up getting 11/11.5 with 305/30/20 and 315/30/20s. 18 offset in the front and 58 offset in the back. im badly rubbing up front, what offset are you using for the 11s in the front? cuz i need to get a new wheel
These offsets are to aggressive up front and to conservative on the rear. are you looking to stay with a 5 spoke? we have a 20x11 square setup that sit perfect on rear and slightly aggressive up front
...Maybe some people who run 11's up front can chime in...
it needs more negative camber or a higher ride height or more offset, from factory the Mustangs that have 20" wheels have a slightly taller ride height for this exact reason. you can run 19X11" fronts with no issue apart from some slight rubbing at steering lock if your sidewall is tall enough
Project6GR Wheels
Los Angeles, CA
Shelby GT350R
Happy Wednesday!
Few Images Came in From Our Customer Getting Ready For Lowering Springs
Project6GR 7 Spoke 20x10 20x11 Satin Graphite
How to Place Your Order
E-mail: [email protected]
Hours of Operation:
Contact Information:
Email: [email protected]
Website: project6gr.com
CHAT IN TO SPEAK TO A LIVE REP!
If you have any questions or concerns, do not hesitate to contact us. We are here to help you!
EdMan63
2022 GT500 Heritage 2024 Bronco Raptor
Happy Wednesday!
Hours of Operation:
What size tires does this set up have? I have a DH with HP and would like to put some 20’s on it. I like this look. I’m in a MI so I would like to put some A/S tires on. Thinking Michelin Pilots. Would 305/30/20 in front and 315/30/20 in rear work?
Project6GR Wheels
Los Angeles, CA
Shelby GT350R
Hello! We spoke in the chat few moments ago! we will keep in touch!
Jmatech
Tennessee
2034 Mustang Dark Horse
What’s your thoughts on a lowered dark horse 1.3” front and .75 rear running 20x11 w/305x30x20 squared with a 24 offset up front and 50 rear? Think it will rub? Think it will fill the gaps? Specifically thinking Mich PS4S as well
Project6GR Wheels
Los Angeles, CA
Shelby GT350R
gaps will be filled in, might have slight rub up front on a full turn or bumps on on highway but it looks damn good for sure ! Here is a similar setup but on nitto NT555g2!
S650 Mustang Dark Horse Handling Pack offset on wheels? 420075385_18332221246100836_2739561621163352926_n
Jmatech
Tennessee
What do you think about a similar setup with 10.5 up front? Or should I go with 10” wide with some 285’s? Still rub?
agreywolfe
Oklahoma
im running 20x10s with 285s up front, no issues with rubbing, you might be able to get away with 10.5
Jmatech
Tennessee
Right on, are you lowered? Mind sharing pix? Trying to get as close to filling the gaps as I can with out rub.
Jmatech
Tennessee
Did you notice any loss in cornering performance going to a narrower wheel/tire combo?
agreywolfe
Oklahoma
On stock suspension but there's easily enough gap between the edge of the tire and wheel arch so you shouldn't see that much rubbing.
S650 Mustang Dark Horse Handling Pack offset on wheels? 20240423_193151
S650 Mustang Dark Horse Handling Pack offset on wheels? 20240420_135117
S650 Mustang Dark Horse Handling Pack offset on wheels? 20241016_120556
Jmatech
Tennessee
would go with 20x10 on 285s
think 20x10 with 285x30x20 will still fill the gap? I really don't want 35 series if I can avoid it. You think this with an +24 offset? or should I go +30 offset? I think factory is +24 if I'm not mistaken
