Does disconnecting the - battery cable reset the TCM on the 2024?
BrianJ77
Still new to Forscan. How do you do it exactly? My PP is not redlining in high gears. It shifts early at like 6k rpm.
I will have to go in and send screen shots. It's been a while since I used it. I will get back to you on it!
JAM486HP
JAM486HP
You go into FORScan and use PCM Clear Transmission Adaptive Tables
You wont be able to redline gears, it's programmed to cut power. Though Sport mode, full throttle should get you more than 6K
HMBSTNG
MN
2024 Mustang GT PP 10r80
Is this something in the OEM tuning? When in Mexico, I do 40 hit and it'll redline all the way till about 115-120 and rpms shifts early and then drops to like 4k and builds back up. Would the re-learn feature fix this? Or only when tuning is unlock to do this? I've been losing races since she puts me out of the powerband up top.
I've tried it in sport mode and drag mode with ADV Trac off and still does it.
Thanks!
