E-brake to drift brake
Mrswear2god
Ontario
Does anyone know if it’s possible with FORscan to make the brake switch act as the drift brake to only lock up the rear instead of all 4 wheels I am unsure if possible but considering it’s all the same wires just a different Pinout gives me hope
npole
Italy
Mustang Dark Horse 2024
Do you mean the handbrake lever yes... not the brake pedal? You may try to enable the Drift Brake option in the menu: (APIM) 7D0-10-03
n_123
2024 GT
I’ve been wondering if you could literally just get the drift brake center console and retrofit it. I’m 90% sure it’s the exact same e-brake on the rear wheel if you have the brembos without performance package.
npole
Italy
There's so many "variants" that every day i find something "new"... so there's S650's without the electronic handbrake? I didn't even know!
They all have electric hand brake... some have the small toggle switch (non PP) or the handbrake lever (with PP). The toggle switch is off or on, but I think the lever is variable by how much you pull on it when in drift mode... so the toggle switch may not be able to be used... unless you want the brakes to lock completely.
npole
Italy
Yes, it's not just a "switch", it is a "potentiometer" (you can decide the level of the lock in drift mode, according to the lever position). My question is, so there's S650 without the "handbrake lever", but they have a sort of "button" on the center console?
Yes... as I mentioned above, without the PP you get a toggle switch for the park brake.
npole
Italy
Thanks, just seen a picture... I didn't know the "handbrake" was an "optional"!
