GTPony24
- Thread starter
- #1
So I ordered mine on April 1st, hoping to be one of the first deliveries. It came in on September 7th. I got a vapor blue GT with perform package, night pony package, grabber BL brakes and convertible. It’s a beautiful car and it did not disappoint in initial appearance. I was so excited after driving my 2018 eco-boost for three years and finally upgrading.
Unfortunately, my exuberance was short-lived as a horrendous, screeching noise started to appear in less than 20 miles of driving. I thought it was a break wear-in situation as it seemed transitory at first, but then it got worse and worse and thankfully some of my gearhead friends figured it out. A piece of metal popped out of my driver side brembo caliper and started scraping against the inside of the rim carving a huge gouge line. Furthermore, it appears that the rear passenger side E brake, had some sort of piece of metal pop out of it once again, scraping that rim horrifically. Both rims are destroyed, and need replacement or resurfacing repair. Then to make matters worse, a piece of plastic door side paneling started visably coming apart from the frame on the passenger side.
So, after less than 24 hours in my possession, it’s back at the dealership and they’re supposed to call me on Monday with a plan. Holding all this constant, the car drove amazingly well it sounded terrific and the infotainment is the best I’ve ever seen. I really hope that I just got one-off bad build and that this isn’t a pattern with the new S650. I would recommend as I did that everyone walk around the car with a fine tooth comb before you drive off, because if I didn’t have a picture of the panel starting to separate before possession it could be an issue.
