Key fob - how to tell which one you're using?
DKnight
2011 Mustang GT/CS, 2015 Mustang GT PP
How can you tell which key fob you are using? Is they a setting that tells you?
ZL1_1LE
SoCal
24 GT, 24 Eco , 22 ZL1_1LE, 21 Rubicon
If I remember correctly if you set up user profiles, it tells you what key is associated with the profile. So two different people can have different profiles depending on the key that is in the car.
JimC
Howell, MI
My car gives a welcome message with the profile name that the fob is connected with.
DKnight
DKnight
Thank you, that was really helpful, I set it up this am.
DKnight
DKnight
I haven't start it up again since I set it up so IDK how it turns out yet. Mine doesn't do the old Ford chime during start up, all I get is the heartbeat. Is the old chime an option?
I’ll need to compare the two to verify but externally the fobs look the same. You could possibly tag / mark one so by time you get in you don’t find out it was the wrong one, assuming door recall buttons (x3?) are na.
DKnight
DKnight
I bought 2 key fob cover in different color so all I need to know is which one is which before I put them on.
JimC
Howell, MI
I haven't seen an option to change it from heartbeat (or are they hoof beats?)
DKnight
DKnight
It did play the old chime every once in awhile when I was driving a rental Ecoboost convertible.
