Newbie questions: GT Throttle Cut Off and Rev Match delay
bbsimpleson
San Francisco
I'm new to the Mustang GT and have a couple newbie questions.
1) When I'm in track or Drag strip mode, I've noticed that the throttle cuts off completely when I floor it and reach ~5000 RPM. Is that normal? I only have some suspension mods, nothing that would cause this.
2) Second question, I've noticed rev matching doesn't work until roughly 15 minutes into a drive. The rev match is enabled and no other settings changed (including cold start). I like manually rev matching but like auto for the convenience, anyone else experience this?
Appreciate any insights, thanks
NVPony
Las Vegas, NV
2015 Magnetic GT PP
I have a GT PP manual. Short answer is no. Cut off is at 7300. Rev match works 100% of the time.
In what gear?
Perhaps the oil isn't up to temp yet?
bbsimpleson
bbsimpleson
San Francisco
In what gear?
1st gear cuts off at 5000 RPMs, and the vehicle is warmed up and still doesn't rev match until approximately 15 minutes into the drive
Rev Match worked perfectly right out the gate when I first got the car. I thought I had accidentally messed with the settings but I don't see anything that could have caused this delay
NVPony
Las Vegas, NV
2015 Magnetic GT PP
Take it to the dealer. Should not be doing that.
bbsimpleson
bbsimpleson
San Francisco
Hey folks,
Solved the issues without going to the dealer. Looks like the result is me messing around with settings and not fully understanding what I did. Doh!
  • Shift indicator was set to 5000 RPMs, thus cutting off the throttle.
  • Rev matching was fixed by factory resetting the vehicle.
NVPony
Las Vegas, NV
2015 Magnetic GT PP
Hey folks,
how do you set the shift indicator?
