At which point do you disconnect/disengage the start/boost or would you continue to charge. Is the bms smart enough to acknowledge the ‘additional’ compensation regarding the alernator?Let's see here. Battery dead, so we hook up a battery charger with Start Boost built in. Then we twist the key to spring things life, and we're worried about a max 2 amp trickle charger? Me thinks not!
Hence, safe being relative and recommended negative.Most (not all!) …should just shut down. In any case, I'd be more worried about ..
