Nice video, but let's consider a few things. This cab is probably 2 years old. 120,000 miles in 2 years is a lot different than 10-12 years. The oil in the car was probably never over 60 days old!Years ago, Mobil 1 sponsored a series of tests involving Mobil 1 and extended service intervals. As part of those tests, they performed engine tear-downs. These short videos will show what the innards looked like. Certainly, as Mobil 1 is sponsoring the tests, they will show well.
There in-lies the complete syn vs mix conversation.Side note: As vehicles gets (much) older, those deposits actually work to help old, worn gaskets keep things sealed up. Ever flush an engine in an OLD car with lots of miles? That can actually lead to negative results!
Myths....synthetic won't magically leak outThere in-lies the complete syn vs mix conversation.
is a dino mix helpful with a seal and then a light syn to keep things flowing or does the added resistance become sludge after awhile and pressure builds? Does full syn too soon eventually drip, burn or excessive blow by?
If you’re always tearing it down you’ll never know, as the miles add why the change since it’s like new?Myths....synthetic won't magically leak out
Plus you have the high mileage motor oils (most of which are synthetic, or a synthetic-blend) with additives specifically for the old seals...
It's not a matter of synthetic vs conventional - it's a matter of dirt and debris filling the gaps.There in-lies the complete syn vs mix conversation.
Isn’t the thread regarding full syn vs blend? What type of detergent package or seal additives are added to the base? Are you saying both move dirt just as well and aint really any diff both get gummy? You mentioned flushing can sometimes clear a clog which was actually helping a seal. If that had not crusted over would it have weeped?It's not a matter of synthetic vs conventional - it's a matter of dirt and debris filling the gaps.
Side note: Beware of clowns making comments when they don't have a clue what they are talking about ... they just like to hear themselves talk.
Is break in oil full synthetic?It's not a matter of synthetic vs conventional - it's a matter of dirt and debris filling the gaps.
"Semi-synthetic" is like >90% conventional oil. There's very little synthetic base in "semi-synthetic" motor oils.Isn’t the thread regarding full syn vs blend? What type of detergent package or seal additives are added to the base? Are you saying both move dirt just as well and aint really any diff both get gummy? You mentioned flushing can sometimes clear a clog which was actually helping a seal. If that had not crusted over would it have weeped?
For 2024, my understanding is that they are running Motorcraft semi-synthetic 5W30 in the S650 Coyote.Is break in oil full synthetic?
I'll try to explain this in a way even you can understand:Flushing a motor will cause it to leak. Ok.
You'd like to prove this how? Is this like the "don't change your automatic transmission fluid because you're just going to loosen stuff up and ruin the transmission"?I'll try to explain this in a way even you can understand:
When a vehicle is properly maintained and the oil is changed regularly, most contaminants are flushed out when you change the oil. When it's not properly maintained, these contaminants can build up inside the engine.
Engines use gaskets and seals made from silicone, rubber, and other material to keep oil from seeping out where engine components meet. However, as these gaskets and seals age and are exposed to pressure, heat, and movement, they break down.
Eventually, the gaskets and seals will be compromised, resulting in oil leaks. This is a fact. Look at any older engine - especially those that have not been properly or regularly maintained - and you will see plenty of oil leaks, commonly around valve cover gaskets, oil pan gaskets, timing cover gaskets, etc.
When oil and the debris it collects is circulating through an engine, this debris gets lodged in the cracks and crevices inside the engine - including where the gaskets and seals are present. Over time, this debris can help "fill the voids" where the aforementioned compromised gaskets and seals might otherwise be leaking.
If you perform a chemical engine oil flush on one of these older engines, you clear out some of the dirt and debris that is acting as a sealant where the gaskets and seals have broken down. When you do this, you risk removing what's actually keeping the leak from occurring.
So, yes, performing a chemical oil flush CAN lead to oil leaks that were not actively present prior to the flush.
You really should do a little research on a subject before making snarky comments. Otherwise ... 'Better to remain silent and be thought a fool than to speak and remove all doubt'.
