You might want to check your air intake / snorkel.
ThreePedalPlow
Saint Louis
I have my front fascia off right now and noticed on the passenger side when Ford installed the front fascia they pinched my air intake / snorkel in a weird manner which I believe would disrupt air flow slightly. My driver side was perfect. You might be able to tell if yours is this way with an inspection camera. I'm not sure you would able to tell with the naked eye with the front fascia still on being most of the intake in the grill is blocked off. Below is how I found it and what it looked like after I fixed it. With the front facia off, I had to remove one clip to adjust it and reinstall it. Another S650 owner in a different online community I follow had the same issue so I'm guessing this is somewhat common.
Before and After:
S650 Mustang You might want to check your air intake / snorkel. 1713846903243-6h
S650 Mustang You might want to check your air intake / snorkel. 1713846992626-m4
Before and After:
Fully admitting i haven’t gone out and looked at ours but since i can see the filter in the pic does that mean one may be to see / correct without removing the front clip (fascia)
Reactions: JAL
JPGC_S650
SC
Yeah, when I upgraded my sway bars, I pulled the stock air boxes and noticed the same issue. Mine was crunched up a bit on the passenger side. It is likely due to the odd angle that the passenger airbox has to be placed in when installed as it doesn't line up on its own. It has to be guided in to seat properly.
37.5726028 / -85.1551411
F150, 2024 Mustang GT Vert
Hmm, in the GT's, didn't believe the Pax nostril/snout functional due to the windshield washer tank being there. In the DH's, both nostrils/snouts are functional and fed directly to the air filter cones.
Mastermind46
Denver
One of mine is like this. You can see it on the GT with everything assembled. It looks like you can fix it from the intake side and not having to pull off the front cover.
JediMindTrix
S650 GT, P702 XLT, P758 XL
This is certainly misaligned. I ended up realigning both of mine when doing my sway bars. Driver side is easy to do with the front cover on but passenger side is much harder to get seated properly.
JPGC_S650
SC
Yeah, they are both functional on the GTs
You can check from the front grill with a good light source at the right angle. I wonder if is happened on earlier builds. I checked mine all looks good.
jimgt2k24
Near Detroit
I think the DH windshield washer tank is in the same spot as a GT.
Seo124
TX
2024 mustang gt
Early model (under 500) was fine. Maybe a crew does it one way, another another way.
jimgt2k24
Near Detroit
This video might help line up the air ducts.
decidave8
mobile AL
2024 mustang GT premium
It does
decidave8
mobile AL
Mine is like that as well I’m gonna take out the air box next time I get a chance and realign it
decidave8
mobile AL
Mine was also like that, I just loosened the air box and was able to reach in and fix it.
