MustangMac67
- Thread starter
- #1
This cars also aren't broken in yet so Ford probably has some weird programming until after break in. But the manual did way better than the 10A. Truly I think you just gotta run the gen 3 vs gen 4 in the wild for real numbers.I know I'm beating a dead horse by watching these dyno videos and commenting...but these new cars having a lower redline than advertised and a lower top speed than the S550 is kind of a joke.
I really hope there is some "magic number" the computer needs to see at a certain mileage that removes that RPM limiter...
So they had 3 pulls right at 440. They seemed happy. Is that about 520ish at the crank?
Which is why the 10A is such a deadly partner to this engine. Keeps it at max HP damn-near the entire time.Average between three runs is:
442whp
387wtq
The power delivery up top is awesome on these things. So flat.
At least one thing's true, you're getting a full-fat nearly-1500rpm's worth of that claimed 500bhp.
With the low and midrange being more or less identical to Gen 3s, it seems like the main improvements would be in-gear rolling acceleration with the Gen 4s. In combination with the extra 100-200lbs these things are carrying, that also explains why numbers from a dig are more or less underwhelmingly the same.
Breaking the car in will definitely alter the numbers on a dyno or the timeslip for a run down the strip...but the fix for the lack of RPM/top speed remains to be seen. The soon-to-be-dying competitors don't have them, that's for sure.This cars also aren't broken in yet so Ford probably has some weird programming until after break in. But the manual did way better than the 10A. Truly I think you just gotta run the gen 3 vs gen 4 in the wild for real numbers.
Yup, seems about 520 at the crank.So they had 3 pulls right at 440. They seemed happy. Is that about 520ish at the crank?
I personally think that 15% parasitic drivetrain loss is too high for modern cars. Twelve percent seems to be the sweet spot for a modern 6 speed car, and that would put 440 wheel hp to right at 500 crank, which would make sense since these engines are SAE tested and they're using SAE correction on the dyno.Yup, seems about 520 at the crank.
What calculation are you guys using?Yup, seems about 520 at the crank.
HP=WHPā1/(1āDL)What calculation are you guys using?
Just curious as I have spent 20+ years in the automotive aftermarket (working for manufactures) and have a ton of experience
There is no standard formula for drive train loss- yes I know people love to throw around 15% - but have seen some pretty big variances
Other thing to remember is that different dynos read different numbers- there are Dynojets- Mustang Dynos (is a type- not specific to Mustang the car) - Mustang Dynos typically read lower - Dynojets seem to read higher
Some people open the hood and blow cold air into the motor- some people keep the hoods shut
Vehicle operating temperature -
We could run a car on the dyno in the morning and see higher numbers then in the afternoon - yes I know they are supposed to compensate for air temp humidity - but not perfect
I mean look at the Steeda dyno at 408rwhp during a storm - I can only imagine high humidity...pretty sure the manual car is not making 40-50 hp more at the crank than the automatic- probably more a result of the weather outside
Dynos are great for tuning or for running a comparison on the same day- or looking at the area under the curve
But like I mentioned- Motor Trend was able to get a GT350 to put down 494rwhp - and I am pretty sure GT350s are not making 600hp -
Not a negative if car is rated at 500hp and putting down higher numbers- if anything is a positive sign of an efficient drivetrain ..getting more power down to the ground is not a bad thing
There is more DT loss with the 10A. The 6M is around 12% DT loss. That puts the crank HP right around factory ratings. 500 crank/440wheelYup, seems about 520 at the crank.
