^ This. Or if it's not a daily driver.This is just to get over the initial low battery charge issues.
Isnât it supposed to progress from 1/4 to 1/2 to 3/4 to full? It hasnât moved in 7 hours and the battery was far from depleted?Leave the charger on for a while. Mine took about 48 hours (not continuous) to go to green. A few times since I have put the charger on and it takes 4 hours to go from 25 to 100% (green).
My guess is itâs defectiveThatâs not good!
I did. Iâve reached out to Noco, unfortunately I already tossed the box so returning to vender probably wonât workIf you got it from Amazon return it. There were some reviews that people had problems with. Too many of these manufactures let the consumer be QC.
Stupid question but are you sure it's hooked up right? Good connection to the positive terminal and a ground?Isnât it supposed to progress from 1/4 to 1/2 to 3/4 to full? It hasnât moved in 7 hours and the battery was far from depleted?
Yes and went back and put our old tender on it and worked as it should.Stupid question but are you sure it's hooked up right? Good connection to the positive terminal and a ground?
This never moves and the voltage doesnât change, nothing is happening unfortunately.If I have my NOCO charging the battery showing full charge/maintain and I open one of the doors the charger will start charging from the begining. It will cycle through the steps for about 10 minutes until it reaches maintain again.
Howâs the inline fuse?This never moves and the voltage doesnât change, nothing is happening unfortunately.
Fuse is fineHowâs the inline fuse?
I just bought the NOCO 5A unit and I plan to try it out this week (hopefully I don't get a dud). Anyway I've never used one of these devices but I remember reading a post possibly by @DCS about how to hook it up without removing the battery cover (I think). Hopefully I can find that post or someone can help me out about how to properly hook it up to the Mustang?Stupid question but are you sure it's hooked up right? Good connection to the positive terminal and a ground?
