- Joined
- Mar 11, 2025
- Threads
- 4
- Messages
- 182
- Reaction score
- 164
- Location
- New Zealand
- Vehicle(s)
- 2025 Mustang GT
I agree. I've seen bleeding done by forcing fluid back into the reservoir. But never heard of circulating air bubbles around the system.I am thinking along the same lines. I don’t see how you could possibly get air bubbles in the fluid at the calipers, which is the most likely place for them, out by actuating the ABS module. The brake system is not a loop where fluid cycles through it; that is the whole reason the brakes work. You push the fluid and it has nowhere to go but to compress the caliper piston. Without opening a bleeder screw and forcing fluid (or air) in or out, I don’t get how the fluid in the caliper is going to get back to the ABS module.
Getting air out of the lines between the reservoir and the ABS module I could see working by actuating the ABS, but I don’t see that working for forcing air in the lines out of the entire system, which is the whole point of a brake bleed.
