bfets
- Joined
- Sep 16, 2022
- Threads
- 9
- Messages
- 558
- Reaction score
- 889
- Location
- Western Australia
- Vehicle(s)
- MY24.5 Dark Horse, manual, Blue Ember, Recaros. XPEL UltimateFusion Fullbody PPF
- Thread starter
- #1
Has anyone connected a battery tender to their car yet? To make it easier on the battery, I like to keep it on a tender if its not going to be used for a week or so.
One option is to connect the positive (red) lead to the connection point under the red cover at the fusebox which is easily accessible but this is on the driver side of the car. I'm not sure if its recommended or safe to use that. My leads wont reach either because it would be too far from the negative negative stud.
The other option for the positive (red) lead is to connect it to the battery directly which is under the battery cover. Downside is you need to remove that cover every time if you dont want a permanent install with a lead with the O-connecters at the end.
And then the negative (black) lead to the jump start stud which is on the passenger side shock tower close to the coolant reservoir:
I think I might just install that more permanent pigtail lead with the O-connectors for a cleaner install and so I don't have to mess with the battery cover every time.
So good to see my charger is made for a Mustang. It says 5.0 on it!
