MustangNoob
- Thread starter
- #1
I feel like I want to post this to inform the community. This is about the Steeda pro air filters. This is not a negative review just (serious) observations.
I used engine air filters from Steeda for about 3k miles, where I removed them and cleaning them. Upon cleaning I noticed few things
Now regarding the #4 when I installed the filters I didn't noticed anything in particular, but following the cleaning procedure (based on the video they provide) I saw the metal piece hanging. I had to cut it by moving it back and forth and was cut very easily. I'm not sure if any metal was detached and sucked into the cylinder. The question here is what are the chances of possible cylinder contamination from the metal mesh and any potential damages? If a metal part falls into the cylinder would it trigger any check engine light?
Talked to customer service and they will be replacing them.
If you have this particular filters or any filters with metallic mesh Inspect them.
1) Dirt embedded within cotton
2) Dirt present in the inner side of the filter
3) Relatively larger than the normal cotton openings. In the size of pinnhead
4) Metal mesh hanging in the inner side of filter
