Non PP extra oil cooler
Stang24
Chicago
2024 mustang
Was curious about everyone’s thoughts on this and if it’s possible to add the performance pack oil cooler on the non performance pack cars. Just doing highway cruising oil temp around 230. After some spirited pulls temps get up to 260s and I’ve even seen 270s once which is way to high. Looks like it would be around $1500 give or take to add the OEM PP oil cooler.
I see MMR has an oil cooler that mounts like OEM for $500 but no info or specs on it yet.
Would it be possible to add the OEM cooler to non pp cars? I don’t think the ecu is tuned differently for PP cars
S650 Mustang Non PP extra oil cooler IMG_8794
S650 Mustang Non PP extra oil cooler IMG_8899
JimC
Howell, MI
Does the kit include a lower driver side grille? On performance package cars that grille is open, but I believe on non performance the grille is blocked off just like on the passenger side. If it is open then the cooler won't be getting any air flow.
Stang24
Stang24
Chicago
2024 mustang
Correct on the non-performance pack cars it is blocked off but you could take that backing plate off. I’m pretty sure it’s removable. Also on the performance pack cars the fender liner has openings. You could spend the money and get a new fender liner or just cut splits into the existing one, which I’d probably do.
ihasnostang
MN
Saturn ion, 201A, EB PP1, Ruby Red ordered 4/30
those temps seem ridiculous for being in chicago
krisk
Even with spirited driving?
Highest I’ve seen my GT PP get was low 210’s after multiple passes on the drag strip when the ambient temperature was in the mid 90’s.
Stang24
Stang24
Chicago
2024 mustang
Interesting. Definitely a must have upgrade then
JAM486HP
I'm seeing the same readings as you on my non PP GT. Seems normal as the PP are running 30-40 degrees cooler. I thought the PP also has a larger radiator.
I have no plans to track mine, and it runs great at 230+, so I have 3yr36K to see if it's a problem. If it starts affecting performance then I'll take issue. Unfortunately I think a warm day at the track this thing would be limp city
ZL1_1LE
SoCal
24 GT, 24 Eco , 22 ZL1_1LE, 21 Rubicon
Mine hoovers between 190-210 at the most, SoCal Temps have hoovered between mid 90's to mid 100's for the last few weeks.
krisk
I may go to the track (The FIRM) tomorrow if my daughter-in-law doesn’t go into labor. If I get down there, I’ll report back on what temps I’m seeing on the track.
Stang24
Stang24
Chicago
2024 mustang
Yes I guess they do also have a bigger radiator. I wonder how much the oil cooler would help without the bigger radiator.
Mustang8
My oil temp with the PP oil cooler stayed around 210-215ish during my track day at Daytona and it was high 80s low 90s out iirc
JAM486HP
I couldn't find any info on that, 650 hasn't been out long enough to see this tested. It would have to help, I'm just not concerned enough to drop $800 or $1500 on a cooler, unless I run into overheating issues. As a daily driver, with some spirited driving, 230-240 is still within a healthy range.
