1. If you look at the high mileage F150's with port+direct, the valves aren't nearly as clean (although, they are still cleaner than DI only engines) as the engines with just portOne of the reasons catch cans are used, is to lesson the build up of deposits on the back side of the valves (direct injected engines). All of the S650 engines now use both direct and port injections. This keeps the valves clean and allows for better emissions. Yes a catch can will trap both moisture and volatile vapors, so if it makes you warm and fuzzy, do it. But ask yourself why this wasn't an issue until direct injection became the norm?
