Rubber piece hanging down behind grille
fraziersc
McKinney, TX
2024 Mustang GT Premium - Rapid Red Metallic
Hello everyone,
I have this rubber piece hanging down from the top/behind my grille and I was wondering what is potentially going on there. Is it something to be concerned about, or is it OK to leave it like that? Would it just need to be tucked back up, or would the entire grille have to be removed to fix it (if it warrants a fix)? Thanks in advance.
S650 Mustang Rubber piece hanging down behind grille image1 (1)
S650 Mustang Rubber piece hanging down behind grille image2
S650 Mustang Rubber piece hanging down behind grille image0 (2)
The Ghost
San Diego, CA
The dealer should be willing to take care of that under warranty. They may be able to take off the black panel above the radiator to access it without pulling off the whole bumper.
Dmulli
2024 Ford Mustang GT
Hello everyone,
Yeah that absolutely warrants a fix, should be totally under warranty for sure.
Stang24
Chicago
2024 mustang
Get a screw driver and just push it up. It will seat itself. It’s an air barrier to direct the air to the radiator. If you want a 3 minute fix use a screw driver and just push it up. U can even use your fingers if you can get them in there
You could DIY as @Stang24 suggests. If it were me; I'd take it to my dealer and have them futz with it; just to get the issue on my service record in case it crops up again later or morphs into a more serious/different problem.
Sure, and give them the opportunity to screw something ELSE up in the process ... :facepalm:
JAM486HP
DON'T take it to the dealer. I just checked mine, had the same thing. as @Stang24 noted it's just a strip of rubber, just press up on it through the grill openings, you can feel it seat back in place, took 20 seconds.
Mustang1987
2024 mustang gt
I avoid taking it to the dealership at all costs lol
ponylover52
mustang gt
same issue here with an array of others. 50k of junk in my eyes hate to say it
fraziersc
fraziersc
McKinney, TX
This is what I ended up trying, and worked within a matter of a few minutes. Just requires some elbow grease 😅 Thanks!
Grabber1
Washington
Mine was also like that. I was able to massage it back into easily with a plastic interior tool. Once it got into place you could tell because the rubber relaxed.
