bnightstar
Bulgaria
2013 Ford Fiesta 1.25i, 2017 GB Ford Mustang GT PP Premium
If the journalists really got to drive the cars hard, then maybe the DH is good. The reviews I saw of the DH it seemed like the journalists mostly got pretty limited time with the DH. I saw one where it was getting dark during the review even because they didn't have enough time. I think it's the one Carlos Lagos did.
Can you link to a few of the reviews where the journalists said they ran all day at Charlotte?
they didn't even do full laps they entered on one end of the track and exited before the lap finish. So yeah DH is fine if you drive it for half a lap :D
Dub347sbf
2024 Mustang Dark Horse
I highly doubt the will not overheat part. Stock Mach 1 was doing same CHT temps as my GT when pushed. So if you push for more laps eventually you will reach limp mode hanse the reason why Dark Horse R has all the coolers replaced. A lot of mods are needed to keep a Coyote cold on track.
That's interesting, ive read a lot of threads on M6G that say otherwise. The diff temp is typically what puts the s550 in limp mode, not the CHT temp. The Mach 1 does come with diff cooler, transmission cooler, and an additional oil cooler like the GT350 track pack. Ive seen threads stating they can take them out for 30 minutes of track time no problem. Also, the Mach 1 track attack (and GT350 track attack), they hit that no problem as well, they have 20 minute lapping sessions. We will see.
Dub347sbf
The DH has a diff cooler, a transmission cooler, and an additional oil cooler like the Mach 1 and the GT350 track pack. Road course days are the reason you buy a DH over a GT. Im sure the DH will last longer than a GT.
Darkness24
US
@ bnightstar
This was a GT not a DH. Before you hate check the facts please!!!
bnightstar
Bulgaria
do you track your car ? On my local track it's very short track just 2 km's with lot's of slow corners and lot's of acceleration at hot temps 86F+ the things that got hot are in that order: CHT temps, then brakes than trans. One lap on a A10 Mach 1 was enough to get same CHT temps as a gen 2 Coyote (my car) and to overheat the A10 to a point where shifts get slower. The coolers do help ones we let go the Mach 1 get down to working temps in half a lap while without the coolers it take me 2 laps to get mine down enough. So yeah Mach 1/Dark Horse are better as they cool faster but doesn't mean they will not overheat. There is a topic in Mach 1 section of Mustang6g that literally was named Mach 1 overheating on track. So yeah in order to keep the car cool you need more than that and based on dark horse R page this is it:
· Upgraded oil system - FS350 oil pan (12 qts) + pump + oil cooler
· Upgraded transmission cooling - bigger cooler than DH
· Upgraded differential cooling - bigger cooler than DH
Would be cool if this parts make it down the FP catalog at least the ones that are missing as the oil cooling for the FS350 is available on FP Catalog.
Dub347sbf
Yes there is a post that states as much, and I've seen many more stating they dont overheat in a typical HDPE session. Again, the CHT is not typically the reason GTs go into limp mode, its the diff temp, and the M1 diff cooler fixes that issue.
As soon as i get my car i do plan on tracking it, i will report back. I do not expect trouble honestly from what ive seen from the GT350 track packs and Mach 1s. Cheers.
bnightstar
Bulgaria
There is a huge difference between a novice in a stock car and an experience track going guy with lot's of mods as with Base GT if you put suspension tires etc on it you will overheat the Motor/Trans faster your diff will work less as you get more grip from suspension, tires. Which is what the OP is experiencing.
I can't wait for more guys getting DH's to tracks and posting results / findings especially looking forward to Car and Driver Lightning Lap to see what it really can do.
Evo1986
My hopes were that the "new" GT is better in oil cooling which prevents from over heating, but it seems that Ford didn't learn from their mistakes and it is still like a hot backed potato.
Can't wait to see the shitty times on the NĂĽrburgring (again)....
Hack
Minneapolis
Mustang, Camaro
I know - just looking at the S650 I thought maybe the big vent in the hood would improve engine cooling quite a bit. I guess maybe it does. I know I've read quite a few threads where S550s have issues with engine temperature on track.
Mod Mustang Racing
Mod Mustang Racing
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
The Base GT does not have a Diff temp sensor in the housing. It is drilled for it but nothing is in there. So this is unlikely the cause.
JS1951
South Flordia
Highlander, hayabusa
With 10 qrts oil and larger radiator car should do at least a lap or two.:frown: I thought diff would be a problem with small lube capacity. I think someone is trying to sell oil coolers.... need more data points.
CanadianRacer
Hi All, New to the forum. I recently took my 2024 Mustang GT 6spd base to my local track for the time attack season opener. It's a smaller track 1.3 miles in a W shape. Lap times seem to range between 1 min to 1 min 15secs depending on car and driver.
At lap 4 I was getting the dreaded limp mode due to oil temps. Being up North (Gimli, Manitoba, Canada) the temps were cool most of the day ranging between 59' to 62' F. I was surprised and a little disappointed.
During the third session I adjusted my driving to keep in 3rd gear through the slower turns instead of 2nd. That slowed the heat build up to get me halfway trough the 5th lap before limp mode.
I'm tempted to get the MMR oil cooler kit since it seems to be the one only specific to the 2024 Mustang GT. I see a lot of universal ones though. I'm wondering if anyone has tried the MMR kit or other kits and what they recommend?
Amended: I didn't notice any issues with the clutch like the OP had. I swapped out the factory brake fluid with Motul 660 before going to the track. Maybe that made the difference since the clutch and brakes share the same reservoir.
Karguy
CA
The S650GT is a cruiser...Used Mach 1 would be a better car if your weapon of choice has to be a Mustang as additional oil coolers and Tremec goes...Wonder if the DH can take the heat in CA on tracks like Thunderhill,Buttonwillow or Willow Springs as Sears Point or Laguna Seca usually have cooler temps in summer compared to the others...But limp mode in spring in canada is a total fail for a track tool...disappointing ! My SS1LE never overheated even in 110 degree weather and I paid for it $42K OTD brand new in 2019...
Stangerous
Space Coast, Florida
Well, we are talking about the base model here. The SS 1LE is not base model. I'm taking my PP to Daytona June 20, we'll see if this holds true for this version. 🤷‍♂️
CanadianRacer
Does your PP have an external air to oil cooler or is it the same as the base GT with a water to oil cooler?
I'm also curious if you have a bigger radiator? I guess it might be hard to tell without knowing the dimensions of both.
Reason I ask is because 2024 PP description on Fords webpage doesn't mention any cooler upgrades. However I noticed some other sources on the internet indicate the 2024 PP has a bigger radiator than the base GT.
