Top will not go up
jamespmoran
Bloomer, WI
My 24GT Convertible is was delivered 11/9. After 11/30 stored it for the winter. Brought it out of storage end of March. Have had the top up and down many times this spring—no issues. Pulled out of the garage this morning to meet some friends for breakfast, little cool, so went to put the top up—nothing. Scheduled an appointment with my dealer for the 1st projected non rain day 6/24. Anyone else had this issue?
Ford Motor Company
Official Ford Account
Dearborn, MI
Ford Mustang
Hi there! I can look into your mustang's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your mustang's VIN?
Pmamba
Chicago
I have not had this issue. Maybe there are fuses to check related to the top motors?
DevilDog
Northern Illinois
2024 Mustang GT on order
That would be my guess as well.
jamespmoran
jamespmoran
Bloomer, WI
Problem solved. Put my windows up, then down, then up again. Hit the top up switch, windows went down, and top came up. Put windows back up, hit top down switch, windows went down and top went down. Kept windows down, hit top up switch, and top came up. Can only assume one of the windows was not registering up or down on its sensors.
rockman 2738
Las Vegas Nevada
2020 Ford Escape Titanium
I have not had that problem but on three occasions while raising the top it appeared to get stuck and stopped moving. The last section was just unfolding. After releasing the button and hitting it again it came up. It was at the same point of the cycle all three times. I have had the car since the end of October last year. I have cycled it frequently. Any time it's over 55 the top goes down. I live in the Las Vegas area so there is a lot of top-down weather.
BobU
Ottawa Ontrio Canada
Had the same problem earlier in the week. Got back a drive and the top would not go up. Started to look up the fuse diagram then remembered that the first thing that happens is that the window go down when you hit the switch. That would give me an indication that there is power to the switch and the switch contacts were working. Rolled up the windows and hit the switch. The windows went down and the top closed normally. Must have been a window out of sequence or a software glitch.
CVCashmere
South Jersey
15 GT Vert w/Steeda lower brace, PP sways, 50th wh
Glad to hear of your resolution. If any of you use the tonneau covers, they will also shut down the top until they are removed.
CVCashmere
