rugedraw
Miami, FL
Ok, so Antho turned it back off on his truck because:
"I could get it to load/move etc but the audio adjustments where hardly noticeable if at all."
I would recommend to try listening to some music using a hi-res streaming service and play with it a high-enough volume to see if you guys notice any difference. If not, then I guess it is not worth doing on these vehicles.
So0_NaSTy
NY
2024 Ford Mustang GT Premium
Let’s shuffle it up Roket. You are correct when scrolling thru drive modes everyone in a 24 Stang sees the same thing. On your center screen, if you on the right side go to fuel economy, does it show a dark horse there? Or a grey GT?
What about in your my Mustang menu?
also shows the GT performance pack
i got a chance to try the Beosound feature in a Mach-E and i can now say with 100% certainty that mine does absolutely nothing. i guess i know what im doing this weekend
So0_NaSTy
NY
Have you tried?
goodlettjr
Houston, TX
Is there a minimum Forscan version that can be used with 24 DH?
What do you mean by min version?
Download the latest version and it will talk to your car.
some folks with late ’23 - early ’24 builds did fine with .61. I couldn’t update with that version on my May ’24 build. .62 (released August-ish of ’24) worked. Agreed @goodlettjr - get the latest download, MAKE BACKUPS of all of your modules FIRST. Then see about mods.
bbarnett
Canuck Land
NA so far
A bit of news, I sent my debug log for bdycm writes to the forscan guys, and they sent me back a build which allows writes to the bdycm! As I said in another thread, they said .64 will be out soon and it will include this fix!
(I asked if I could post the link/etc, but they said no, please wait.. it'll be out shortly)
So with that news, I was going to try to update the 'walk away' locks, but my bodycm ends at 726-96, there is no 726-97. So the spreadsheet and initial info at start of this thread don't jive.
Can anyone confirm that their bdycm ends at 96?
And, any suggestions on walk away locks?
Has anyone tried this with a mongoose? Does the mongoose show addresses (never used one)?
So0_NaSTy
NY
I can’t recall exactly, but I know when doing walk away lock, it worked with no issue.
bbarnett
Canuck Land
NA so far
Huh. Did you use a mongoose?? Because forscan (for me, and most others I've seen) cannot even write to the bdycm at all, until this new update re: 64.
(Maybe this broke with the new bdycm update? Rev1/2 or whatever?)
But my point is, how *can* it work, when forscan stops at 96? Could you confirm that forscan stops there for you?
**Confused**
So0_NaSTy
NY
**Confused**
0 idea what mongoose is. I can write to the BCM no issues. Done it multiple times. I don’t remember what it ended in, whatever the spreadsheet said honestly.
