Active Noise Cancellation
Illini4
Perryville, MO
2007 Mustang GT Convertible, 2024 Mustang GT Convertible
Still having problems with booming noise, apparently coming from Active Noise Cancellation equipment. Dealer is going to disconnect the ANC microphones on 7 January. Anybody have a better idea/fix for this problem? It's a GT convertible, so there is no connector under the headliner (no headliner).
Pmamba
Chicago
I’m glad you brought this up because i thought I heard it again recently….
bbarnett
Canuck Land
NA so far
https://www.mustang6g.com/forums/threads/forscan-codes-s550-mustangs.98260/page-3#post-2155503
In the above there is talk about using forscan to disable it. That's for the S550, but the 650 should be the same?
Here's info from the spreadsheet in the forscan forum on this site. It does look like you can tell the car there are no mics, and also just turn of Software ANC.
Have you tried this?
(The dealer should be able to do this too, without a physical disconnect)
S650 Mustang Active Noise Cancellation anc
Illini4
Illini4
Perryville, MO
Dealer doesn't have Forscan. I've suggested they either replace the ANC equipment or disconnect the microphones. They are concerned Ford wouldn't cover the cost of replacing the ANC equipment if that didn’t fix the problem. They don't think Ford will cover the cost of disconnecting the microphones either, but agreed to do it. I could do it myself, but don't want to let them off the hook until this is fixed.
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
GT’s do not have ANC. They have the physical sound tube under the hood. ANC is for the Ecoboost.
Pmamba
Chicago
My car is going in again next month for the body work. I’m going to bring this up and mention that open ticket number you have. At the end of the day, Ford should be troubleshooting this to find a fix. Unplugging or disabling any ANC should be part of troubleshooting.
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
Unless they added ANC to the V8 S650‘s (which I highly doubt as it’s never been brought up) you have nothing to bring up. Those forscan codes shown in the other post are for the Ecoboost.
By the way troubleshooting is it locate and find a “trouble”, not a supposed feature. As ANC and the sound tube were/are considered features Ford isn’t going to do anything. That’s what the foru are for. 👍
Illini4
Illini4
Perryville, MO
Dealer has verified that my GT has ANC. A feature that isn't working properly is trouble.
The dealer uses a different tool and interface, I think it’s IDS. AND YES, they very much can disable ANC, this is a fairly common request for ecoboost trucks.
it’s not that great like a set of noise cancelling headphones but it’d does tamp down small, annoying noises.
If for no other reason they should do this as a troubleshooting method.
Pmamba
Chicago
Even if there is no ANC there is absolutely something wrong. It literally sounds like a bass note from a subwoofer.
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
I stand corrected on the S650. Post #13.
https://www.mustang7g.com/forums/threads/has-the-gt-also-fake-exhaust-sound.162098/
OK from the 8/1/24 Order guide.....
For Ecoboost base and priemium
S650 Mustang Active Noise Cancellation Screenshot 2024-12-15 at 11.19.25 AM
S650 Mustang Active Noise Cancellation Screenshot 2024-12-15 at 11.19.35 AM
For the GT base.
S650 Mustang Active Noise Cancellation Screenshot 2024-12-15 at 11.21.56 AM
For the GT Premium No mention of the vert.
S650 Mustang Active Noise Cancellation Screenshot 2024-12-15 at 11.22.44 AM
Illini4
Illini4
Perryville, MO
Dealer attempted to disconnect the ANC microphones today, but found the ones that were supposed to be in the rear speaker compartments had not been installed. The connectors were there, but no microphones. The only microphone installed was in the map light console. Checking to see if disconnecting that one makes a difference.
Pmamba
Chicago
Interesting that it’s missing. I wonder if there is any chance the issue could be related to them being missing like it’s over compensating from just the front.
My cars in the shop for body work right now going to call them this week and have them look at the noise. I’m not at all confident they will care to even look at it. They gave me the car back with the brake peddle noise last time.
Illini4
Illini4
Perryville, MO
Disconnecting the map light compartment microphone had no effect. Now I'm wondering if the problem stems from the missing microphones in the rear seat speaker compartments.
Pmamba
Chicago
Are they able to confirm the convertibles are supposed to have those? It definitely seems like it could be a possible issue.
Maybe one of the techs on here can confirm they should be there.
