Does anyone else have a creaking noise coming from the rear passenger side of the car?
DFW
2024 Mustang GT Performance
I also hear a creaking noise from the right rear seat area of my car. The noise occurs whenever I'm driving at low speeds, regardless of the road conditions. I suspect the noise is related to the rear interior trim panel(just above the armrest), as I can hear the same creak when I press on the panel with my hand. I took the car to the dealership and went for a ride with the repair engineer. He offered to fix the issue by disassembling different parts of the car to investigate, which would be covered under warranty. However, as a fellow sports car enthusiast, he warned me that removing plastic trims might lead to additional noises. Given this, I decided to tolerate the noise for now until I have more time to track down its exact source.
PS: It doesn't sound as loud as in the video, but it is definitely annoying when I try to listen to not-so-loud music and have my windows closed
I have this same noise.
Did you ever resolve?
erocker
Milwaukee, WI.
I had a little creaking at low speeds over bumps. Lubricating the rear seat hinges with some synthetic spray lube fixed it.
I had the same issue and today I had time to check this out and found it was in fact the rear passenger seat hinges. For anyone else who has the same issue just fold down the rear seat, go for a ride and see if the noise disappears, mine did and after lubrication the noise is gone completely with the seat back up. Thanks a lot for the tip.
DFW
Tried lubing the hinges and taping the latch with Tesa tape.
still have the creaking sound.
Seems it is behind the side panel.
DFW
Just removed the side panel and replaced all the panel clips.
Sound still there…..
DFW
Well….got tired of trying to figure out the noise issue
Took it into local Ford service.
Turns out the weld between the parcel shelf and the D Pillar is missing.
This is causing the noise to happen as the body of the car flexes And those two pieces of metal rub.
Looks like I will be without my at for a month or so.
Knoxx
Poland
2024 Ford Mustang GT
Hey, did you receive any official document with description of this issue from Ford service? I'm asking as I'm having the same issue probably, it would speed up the identification of the issue in the dealership I guess.
Jeddah_Racing
Jeddah
2024 Mustang GT PP
Hey, did you get your car back and was it fixed by fixing the weld thingy? Please let me know its driving me crazy this sound 😢
GK292
Austria
Jeep Cherokee XJ 4.0
I had a similar sound on higher speeds. Turned out the bolts holding the rear wing were not tightened fully. When you open the trunk there are two small bolts and behind the rubber plug one bigger. Retightened them and the sound is gone.
135Hoser
2024 Dorkhorse, 2024 CR-V
So I still have this issue ongoing, not sure if its acoustics or what. I tried lubricating the rear seat hinges.
I'm starting to I think I have a missing weld
jassson
US
Hi, I talked to them guy and he was frustrated with the sound that he traded it in for other cars. Meanwhile my car is at the dealership. Hopefully this time they do something helpful.
jassson
US
Unfortunately mine has spoiler delete from the factory so that ruled out the possibility for me. Thx for the post tho, I’m sure someone else will find it useful with the QC of these new Fords……….
xrs
Canberra
Yep, I can get my car to make a noise if I drop the front driver (USA) passenger (AUS) wheel down an incline 20 degrees or greater and flex the front chassis. So, one front wheel will be down the incline and the other will still be at the flat top, then clunk noise.
