MidLifeManifustang
- Thread starter
- #1
For those who are experiencing some of the same annoyances with their S650 as I have, here's the list of issues I took to my dealership today and the outcomes:
- Audio via CarPlay is intermittently silent (detailed post: CarPlay audio intermittently silent)
- May be fixed soon - quoting my repair order: "FORD IS AWARE OF THIS CONCERN AND ARE DEVELOPING SOFTWARE TO CORRECT PLEASE CHECK AT YOUR NEXT SERVICE". The dealership told me it can affect Android as well as iOS devices, and may be an OTA fix.
- Back window on passenger side must be raised and manually tilted forward before front window or it doesn’t seal properly (detailed post: Back window not always sealing right)
- Fixed: The RO just said "ALIGN BOTH RIGHT SIDE GLASS" and mentioned removal of the passenger door trim, which suggests they may have adjusted the track on the door window as well as tweaking the rear window glass
- I'm going to try lubricating the track to prevent recurrence, as other users have suggested.
- Locking and unlocking by touching the door handle is intermittent / often unreliable (detailed post in this thread: Delay lock touch button)
- Not fixed - probable design flaw. The service advisor let me speak directly to the shop foreman / tech and he said the antennas on the Mustang aren't as large as those on my '21 Explorer (my point of comparison for proper operation) and the behaviour is typical and he can't do anything about it.
- Lane centering assist feature is unusable because it keeps warning to keep hands on wheel while hands are on wheel (detailed post: S650 Mustang -Keep hands on steering wheel message)
- Not fixed - probable design flaw. The tech told me the system relies on rotational input (not pressure or weight on the wheel) to assess whether or not you're holding the steering wheel. I asked it if was possible to change the sensitivity on it, i.e. require less rotation, or require it less often and this is not possible at the dealer level.
- So if you're using this feature on a straight and flat road that requires no steering input, the system will keep warning you to keep your hands on the wheel unless you're providing artificial steering input just to let it know you're there.
- At highway passing speeds and full throttle, the engine hits rev limiter before the automatic transmission shifts and the engine cuts out for a second (detailed post: Rev limiter or fuel cutoff before A10 shifts)
- Not fixed - Since the issues is happening only at pretty high speed, they obviously didn't attempt to replicate the issue. At first the tech was telling me I had hit the governor limit (no, I said, my speedo is indicating well short of 250km/h [155 mph] and it keeps accelerating hard after the delayed shift) and then he suggested it was the timing being retarded for a fraction of a second to soften the shift (no, power is being cut off entirely for a full second). He finally seemed to get there was a problem but shrugged and said it's unlikely we'll be able to do anything about it because:
- Dealers don't have access to tweak the shift points
- Resetting the transmission would just make the car drive weird for a while and probably not fix the problem
- If I provide a data log so they can see the issue happening, the best he could do would be to send it to Ford but then Ford would be unlikely to fix it because, he said, changes to the tune require government emissions re-certification, which costs "millions".
- It seems my best hope on this one is for someone to unlock tuning capability at some point.
