Ford Performance Oil Cooler Kit
Ford Performance has released their own oil cooler add-on kit for the 2024+ Mustang, using the same factory parts as any Mustang GT Performance Pack or Dark Horse.
https://performanceparts.ford.com/part/M-6642-M50D
The kit uses the same type of oil filter as usual in contrast to how MMR's kit uses the more expensive cartridge filter from the GT500. the fact that this is made with OEM parts means that you will likely even be able to install the air guide from the Performance Pack models too, which appears to be part number PR3Z-8311-A, though i do not make any promise that it will work; this is an assumption based on the information i have
S650 Mustang Ford Performance Oil Cooler Kit 1745345578839-v8
S650 Mustang Ford Performance Oil Cooler Kit 1745345609811-qr
What's the price tag?
GrabberB
2024 Mustang GT Performance Pack, 2024 F-150, 2000 Dodge Ram 3500 800 HP Cummins
I think there would be one more part or modification required to pull this off.
Left Front Inner Fender Liner (Slotted) or cutting some slots in the non-PP fender liner. Not sure how the latter will hold it's shape over time (Rigidity speaking).
