Horn sounds when exiting car
5.0ALM
Brisbane, Australia
Anyone know how to stop horn from sounding when exiting car. I have searched interweb and manual but can’t find answer..I only want it to sound when locking or door/boot not completely closed..Is quite annoying when just getting out & horn sounds for no reason..(that I could find)..
Thanks for any help..
This was driving me insane, especially at 06:30 in the mornings with my neighbors bedroom <10m away. :explode:
I did find holding the fob up against the rear 1/4 window whilst exiting prevented the double-honk 99% of the time.
Sensing the low powered signal through the glass meant it took a few goes to find the optimum spot.
We're RHD down under, but try it on your corresponding side.
S650 Mustang Horn sounds when exiting car 20241229_131735_1200-
Right hand used to take photo, but you would touch the lock touch sensor with your other finger/hand whilst holding the fob about here.
When it went in for it's POM service (Piece of Mind service - it's a complimentary dealer check up we get @ ~3 months in Australia) I asked the dealer to disable the double-honk, which they did.
S650 Mustang Horn sounds when exiting car poms_2-
Piece at last. :whew:
It was a stupid feature, and one that should have been in the GUI to disable, just like the Key Detection Alert double-honk upon exiting the car whilst it's still running.
Get your dealer to do it, next time it's in. :like:
The dash display gives me option for sensors on / off & defaults to off unless I change it.
Will try setting to on when getting out.
No, that's not it. I never touch that and I've never experienced the horn beep like you describe. Is your car from the US or foreign?
Paul2020
Paul2020
Australia
2024 Mustang GT Atlas Blue
They all built in US, but mine is RHD for Australia.
Since ALM had his disabled by dealer will get mine done when complimentary service done..
Europe
There are quite some important differences between US Mustangs and overseas Mustangs when it comes to warnings, chimes, and other settings.
Ok. I'm wondering if this is an export programming thing then. Good luck!
DJS068
Adelaide, South Australia
2024.5 Vapour Blue Mustang GT
Thanks Alan
That is probably true if red button not pressd. In my case the engine has stopped & accessories are off as well.. 99% of the time engine & acc are off when I am getting out of car..
Mine does is on occasion too, and I haven't figured out what the cause is.
I did find a setting where I could turn off the horn when locking the car (I think that's what I did), but the horn still sounds on occasion.
Europe
Can you describe me real life events when the horn sounds on your car so I can understand when it does that?
DJS068
I'll have to take note next time of what conditions it happens under.
I have a feeling that it's when I unlock it with the key and then open the door, but maybe there's more to it, as it doesn't always do it.
Whenever it does though, it gives 2 quick horn blasts.
Europe
The 2 quick horn blast normally do it when you step out your car with the key with you while the car still is on.
