Love the car, but I have 2 big disappointments
DCS
Ocala, FL
I am just past the two-week mark and am loving just about everything on the car. But, I do have 2 huge disappointments.
The first, because it is more impactful on a daily basis, is that the touch screen is plastic, not glass. And, it scratches very easily. I already have 2 permanent fingerprints on the screen where the home and back buttons are and one starting on the Home Screen where you choose the current source or phone. It looks like even the microfiber towel I was using to clean off regular fingerprints is putting fine scratches across the whole screen. I don't notice it much with the top up, but when the top is down and the sun shines in, they are quite obvious. Only 15 days in and this happened! My 2015 was 9 years old and didn't have a scratch. What is this going to look like in 1 or 2 years? Very disappointing! If anyone has suggestions for cleaning that won't scratch or repairs, please reply.
The second disappointment will occur less often, but is none the less very disappointing. With the top down, when I pass 85mph, the windshield shutters violently. Not just the glass, but the entire structure from the A-pillars right down to the rearview mirror. I have the strut tower brace and I believe all Verts have the sub-brace and still this shuttering. My 2015 was rock-solid with the top down to at least 120mph. Never really tried to get her past that. No idea why this would be. The structure of the car is virtually the same from the S550 to S650 so why this development. Again, if anyone has some input here, would be much appreciated.
https://theocdplug.com/search?q=s65...ance&filter.p.m.custom.compatible_models=S650
Edson8r
Dallas, TX
2024 Ford Mustang GT
DCS
Ocala, FL
The screen is not plastic, it’s glass all the way across. You either have the plastic still on there or you’ve had something on your fingers that has etched the glass.
Try rubbing alcohol/water mix or a glass cleaner and microfiber towel using little to no pressure. Even the softest microfiber will scratch with pressure.
Below us from an automotive write up
The Mustang graduates from the Sync 3 to the Sync 4 infotainment system, and every model comes with a 12.4-inch digital instrument cluster and a 13.2-inch touchscreen that can be combined under a single piece of glass
https://theocdplug.com/collections/mustang/products/mustang-s550-screenprotector
ListedGuru
Mercury
I got my screen protector for the non premium GT off of LMR. They have one for the big screen as well. Did it to help keep my screens look clean and avoid scratches like you would with a cellphone.
https://lmr.com/item/OCD-S650DUAL/mustang-screen-protector-dual-display-2024
https://lmr.com/item/OCD-S650LGD/mustang-screen-protector-dual-display-2024
So how are you liking the screen protectors so far? Would you say the clarify of the screens is as good or better with the protectors compared to without them? Also I wonder if we really need a protector for the main screen in front of the driver? That one isn't touch screen correct but maybe it's still a good idea?
Edson8r
Dallas, TX
so far it’s not bad at all, it is a matte finish so it reduces glare although I never had any issue with seeing anything before the screen protector, it does help keep finger prints to a minimum or not as noticeable at least to me. I do agree regarding the main screen for the driver I was debating if I wanted to put it on mainly because that screen never gets touched. I may take it off or leave it on. They don’t affect how clear it is at all so that’s a plus.
ListedGuru
Mercury
Thanks for the feedback. I see someone else posted a link to a single protector for the center screen for sale on Amazon. I recognize the company as I have used their products on phone's before so I might give the single one a try.
Edson8r
Dallas, TX
Yeah for sure you definitely would want the actual touchscreen. I don’t really see the purpose for the other one since nobody will be touching it. Unless you want it to look all the uniformed then I’d understand that haha
ListedGuru
Mercury
Yeah that's a good point about wanting it to look uniform but really I wonder if anyone else besides me would notice, lol. I guess it's possible the other screen could get damaged when you clean it if you use the wrong cloth, etc or something was stuck to the screen that smeared and scratched it when you clean it. So I guess maybe having both protected isn't the worth idea :)
https://a.co/d/5474MWv
Another option, no experience with it. Not sure how it would look with your premium screens.
I just measured the right side of the premium screen in the car. The actual rectangle "touch" area (darker screen behind the glass) is 13.2" corner to corner, just like the protector indicates. There is additional glass above and to the side of the rectangle.
I think it will look just fine if it is perfectly covering the touch area. I just ordered one.
theMANIMAL
CA
‘21 JLURD
I have one sitting in my cart, but we are probably a month out from our delivery. Just a 301A, so it should fit perfect for us. If you happen to remember, follow up and let us know how it works out and if you’re happy with it? Spigen makes good phone products so I have high hopes for this screen protector.
Dxm
NYC
If you look closely, there’s a screen protector on both screens that is plastic. You can really see it on a sunny day.
I received this last week. Will be making some time to install soon.
TripleshotMcC
TripleshotMcC
Palm Desert, CA
2024 GT Premium Convertible
So you believe there is a screen protector that is below that big sheet of plastic with the "pull here" tab on it when I took delivery? I have removed that big oversized plastic, but didn't know that there was another plastic screen protector from the factory on the glass. No one ever said to remove that. I did install the Anchor Room protector in non-matte and it looks good, a slight orange peel texture is visible but not to the touch. Seems to work just fine.
Dxm
NYC
I don't have a "pull here" tab. I see plastic rectangles that are glued onto both screens, I can scrape it with my thumb nail....
