DeluxeStang
- Thread starter
- #16
Valid point, but GM chassis and magnaride are scary vs downforce. Also the ability to overcome slight cornering deficiencies in the straights with not only the 200HP power difference but the ~800lb weight difference will impact the results. If you go back and look the Viper is a MONSTER because of the "low" weight.
Cliff Notes - The ZR1 is ~800 lbs lighter with 200 more HP... Downforce? maybe
It's gonna be a fun comparison for sure, I'm just really happy both these cars exist to be honest. The ZR1 will take it on the straights for sure, but will it overcome the cornering advantage of the GTD? That will remain to be seen.Downforce is a different question entirely, the GTD has both more peak downforce and less straight line downforce thanks to its active aero vs the static aero on the ZR1
It is worth noting while the GTD is more of a handling car than a power car, it's still moving at a pretty good clip down the straights, I believe it was hitting 170-180 down several straights. The ZR1 will probably hit around 200 is my guess, which is insane.
The way I see it, we went from having 0 American cars capable of a sub 7 lap to multiple options in less than a year, which is just badass.
