Where are turn signal flashers on 2025 S650?
abstruse1
2025 GT500
I can't find this flasher(s). Maybe the flasher is integrated into some other electronic device. When the signals are operating, the clicking sound comes from a small speaker under the driver's dash.
What I'm looking for is the wires that send +12 to the L and R flasher(s) to use to operate a relay for the side illumination lamps I'm installing. Thanx.
if you have mirror indicators, you will need to tap into the wiring from the DDM and PDM. if you dont, you're gonna need to run some wiring and do custom stuff from the LDCMA and LDCMB. modern vehicles dont have relays for the indicators, but the current is electronically controlled by the BCM
edit: just realized you mentioned needing 12V. you probably arent gonna find more than 5V on any of those things i mentioned, since everything is LEDs
abstruse1
2025 GT500
Thanx, guys. I talked to a Ford mechanic who explained a lot about the electronics of these new cars, and I concluded that I can't do this like I was thinking about. So I've ordered two small magnetic proximity sensors that I'll mount by the turn signal stalk. These will trip relays for the lights.
