Pierre
- Joined
- Jan 22, 2024
- Threads
- 5
- Messages
- 40
- Reaction score
- 28
- Location
- New Orleans
- Vehicle(s)
- 2024 Mustang GT Premium
- Thread starter
- #16
You are right, need to drive more.
You are so right I’m 63 and it’s harder to crawl around on the concrete.I used to laugh at people who had others change their oil. I always did it myself since I was 16 on my '55 Ford. Now poooff, I'm 75, my dealer labor costs are fair, I don't spill oil on the floor of my garage, I don't have to jack up the car to crawl underneath, getting up is the hard part and I don't have to recycle the old oil. I can get a full syn oil change for around $100 with tire rotations on my Mustang, Escape and F-150 and out lin less than an hour. I can still have fun and get dirty servicing my motorcycles, boat motor, tractor and lawn equipment.
Just to keep the heart healthy. Piece of mind.Why change the oil at 1000 miles?
If something is bad at 1000 miles, it will get really bad very quickly. Did you send it to a proper oil-testing facility?Just to keep the heart healthy. Piece of mind.
Lots of people prefer to get the factory fill out fairly quickly because it can have a higher wear metal content .... since it's in during the break in. My factory fill had high Silicon levels, which is likely just RTV type sealants and not air filter issues, but it's good to note that in case it doesn't decline.If something is bad at 1000 miles, it will get really bad very quickly. Did you send it to a proper oil-testing facility?
If you used an oil that meets the requirements noted in your manual, they can't cancel your warranty. Save your receipts.Ford may cancel the warranty and blame you. They will test your new oil to be sure it is at factory requirements.
Many perform their first at 1000 mi / 1600 km. It's officially broken-in then. Something of a milestone and celebration.
I believe it's also practical. Not only is there a certain amount of machining trash left over from the factory build, the engine internals are shedding the most materials during break-in (IMO). It's a step towards goodness not only to drain as much of the physical material as you can, but give the initial oil filter a high-five, then replace it.
https://www.mustang6g.com/forums/threads/first-oil-change-and-analysis.132878/page-2#post-4125644If something is bad at 1000 miles, it will get really bad very quickly. Did you send it to a proper oil-testing facility?
That's cool. Countless people follow the Owner's Manual and continue to enjoy their vehicles. Some go above and beyond, from either personal preference or unique conditions (tracking, modifications, etc.) As long as the Maintenance Requirements are met, there should not be any issues.I say 7500 miles or one year. But continue to check the oil level regularly.
I document everything I do on the car.If something is bad at 1000 miles, it will get really bad very quickly. Did you send it to a proper oil-testing facility?
Doubt it.It costs maybe $15 more to take my vehicles to the dealer and have them do it than it does for me to buy the materials.
My last oil change was in my 2021 F-250 7.3. Total cost was $77.88. Oil and filter cost is around $60-65.Doubt it.
What did your last oil change cost?
You can buy two jugs of oil at Walmart for $20 each and a filter for $7. $47My last oil change was in my 2021 F-250 7.3. Total cost was $77.88. Oil and filter cost is around $60-65.
