Forscan ACM - GT with B&O 12 speakers
allenouo
Australia
S650 Mustang GT
Can anyone with the B&O 12-speaker system share their 727-01-01 settings?
My as-built value is BC33 14FC 103F, which indicates:
  • SO Tweeter Only
  • Subwoofer Not Used
  • Center Not Used
Does this mean the subwoofer in the trunk and the center amplifier aren’t being used at all? The audio quality of this system isn’t great, so I’m wondering if this could be the reason.
I also noticed that when I turn the ignition off, the screen’s primary and secondary colors revert to the default settings. I’m not sure if this is normal behavior or if I accidentally changed something while playing around with Forscan.
Thanks in advance for any insights!
ScottB125
By chance, could you post your as built values for 727 01 02 and 727 01 03?
I changed mine and now only one speaker works.
thanks
Scott
Europe
@roket
I don't know if this was the case with Roket, but I remember something he told me about that he found out that his speaker was not working.
I tagged him to see if the issue he had has to do with this.
I have Premium with 401A package with the B&O 12 speakers.
This is my data:
727-01-01303314FE10B5
But remember, you are from Australia, so there are some differences in the lines because the way the radio works in NA vs Australia.
Compared yours vs mine, seems that we have the same setting since you are talking about the third and fourth digit on the first line which we both have set to 33.
@roket
This is my data:
only issue i have had with mine was i forgot the plug in the subwoofer after swapping out the tail lights
@roket
This is my data:
Mine are the same...
