HOW MANY G in a straight pull?
Ewags81
Midwest
2024 dark horse
Just curious. I haven't really cut her lose 100%. And it's still cool outside. But how many g-forces are you seeing on the dash in a straight line pull? Gt or Dark horse? Manual or 10-speed? I know the dash probably isn't 100% accurate but you got to figure we're all calibrated about the same. So far I've gotten .75 I feel like that's probably at the first into second shift point.
RacerMach1
Ahead of you
2021 Mach 1
I got 1.2G on a launch once when I was stock with 6 speed manual using launch control. I am tuned on e85 now and cant bang off another 1.2, usually around 1.15. That 1.2G launch I dead hooked like no other time.
Ewags81
Ewags81
Midwest
2024 dark horse
nice. i haven't hit it from a dead stop yet just out of break in so just aggressive onramp type stuff so far.
Ewags81
Ewags81
Midwest
2024 dark horse
i did get -1.22 on brake check trying to scare the shizz out of my sons though. 😄
Europe
Am I the only one who does not know anything about G-Force and how it is measured, how to read the numbers and how to know what is impressive and what is not?
I know a 0 to 60 in 4 seconds is quick. But I have no clue if 1 GeForce is quick or 200 G-Force or maybe 400 G-Force LOL. Those numbers don't say anything to me.
G force or Gs is a measure of acceleration, the unit being based around Earth's gravity of ~9.8 m/s^2, or about 21.92mph per second. GeForce is unrelated and refers to Nvidia's line of consumer graphics cards. 200 Gs is basically an instant death, with 400 Gs being an even more instant death, because it means that someone has, for example at 400 Gs, somehow started to accelerate at a rate of 8,768 mph per second.
as for how quick 1 G is, the average person can withstand about 3 to 5 Gs before becoming dizzy and things like "grey out" (where your vision quite literally becomes greyscale), and highly trained fighter pilots can withstand up to 9 Gs for a second or two at most. however, the average person can withstand very high Gs for a very, very short amount of time, but it may still cause damage. in a moderate speed car crash, around 25 Gs is to be expected, and severe crashes can reach 50 Gs or more, with the world record for the highest amount of Gs experienced involuntarily and living being 214 Gs by Kenny Bräck during an IndyCar race in 2003.
for road cars, most high performance vehicles will have their peak Gs be lateral (sideways) and be around 1 G, with the current world record holder for highest G force from a road car being 2.3 Gs from the Donkervoort F22.
Ewags81
Ewags81
Midwest
2024 dark horse
in United States software, go to my mustang, auxiliary gauges. G-Force meter should be in the middle. probably not accurate. but I figure we all have the same car so the car to car has to be similar. just something fun to play with. I was hoping everybody would give me a number to strive for. my driveway is underwater so the car won't be coming out for some time.
Europe
Unfortunately I haven't pulled the car yet. I'm still on 180 miles. But will do later on.
Ewags81
Ewags81
Midwest
2024 dark horse
update. non-handling pack car so just summer p0. finally warmer tires, maybe a little too much pressure at 39 PSI hot. 3200 RPM launch control. no lift shift at 7250. still 0.84 g on launch. any more RPM blows the tires off. at first tire change I'm going to upgrade to the larger wheel tire package so hopefully that helps 😉
The direction of the G force is important. Fighter pilots encounter vertical G hence the reason they wear G suits with inflatable pouches. Cars only produce lateral G unless you have a very fast hump bridge crossing!
F1 cars routinely produce 5G under braking and cornering
135Hoser
2024 Dorkhorse, 2024 CR-V
You'd do better going to a stickier tire compound, or give up hope expecting to hook from a dead stop on an unprepped surface.
Fruitstang
2016 Mustang GT Convertible
Completed and in Si units:
1 G = 9.81 m/s per s
1 m/s = 3.6 km/h
9.81 m/s^2 * 3.6 km/h * s/m = 35.28 km/h per s
60 miles/h * 1.61 km/mile = 96.6 km/h
=> 96 km/h / 3.6 m/s / km/h = 26.83 m/s
With known average 4.3 s 0-60 mph:
4.3 s * acceleration_average m/s^2 = 26.83 m/s
=> acceleration_average = 26.83 / 4.3
= 6.24 m/s^2
G_average = 6.24 / 9.81
=> G_average = 0.64 G
But that's only the average. During shifting "G" will be negative due to friction of wheels, bearings etc. and air resistance, and while in gear, acceleration will increase and then decrease again.
