MT82-D4 manual transmission in 2024 Mustang - should I be worried?
Jrws1014
North Carolina
Dave2013M3
El Segundo,Ca
Instant Action
392 Wrangler, '24 VB Mustang GT PP Vert 6sp
Anyone know if the MT82-D4 has the same internal ratios as the Tremec?
BlackFerret69
I had basically the same question. My 96 mustang is a generation earlier transmission that had a weakness in the 3/4 gear fork. It was latter fixed however my transmission never received the fix. It currently has 170,000 miles on it without failing. Probably the reason it hasn't failed is I don't force shifts and allow it to drop into gear.
That said, my primary reason for getting the Dark horse was because it has the Tremec transmission and I wanted something that would last. I plan on putting about 200,000 miles on the car and at the current rate, it should last the rest of my life.
I have an '06 with the TR-3650 Tremec, it is not exactly a smooth shifting transmission, even with a short throw shifter. I occasionally have the 2-3 lockout, but I just put light pressure on the gear shifter, double tap the clutch and it goes right in. I also ordered the DH with the Tremec 6M. I am wondering how much difference there will be between the two other than the extra gear.
I did look at the gearing in both and the TR-3160 seems to have a much closer ratio between 1st and 2nd than the TR-3650, not to mention the higher rear gear:
Gear:2006 GT (TR-3650):Dark Horse (TR-3160):
Rear Axle3.553.73
1st3.383.25
2nd2.002.23
3rd1.321.61
4th1.001.24
5th0.681
6th0.63
Reverse3.382.95
I am really looking forward to rowing the gears on the DH!!
Dave2013M3
El Segundo,Ca
Is this good ?
The Tremec has more aggressive ratios over the Getrag MT-82D4. They are not the same, 1:1 for the D4 is 4th, while it's 5 the for the Tremec in the DH.
VaporGT
100%
Do not give us an engine that has to spin to 7,000 RPM and beyond before it finally wakes up, and then saddle us with a transmission that can only handle 4,500 RPM shifts. That's the dumbest piece of engineering I've ever seen in my life. Like I have said before, the MT82 zaps every bit of the fun out of this car. I will never buy a MT82 ever again. Ever.
If you want to drive slow, never "race" or "mod" the car, then why buy a Mustang GT?
If you do want to race, mod, or enjoy the speed of the car, then why buy a MT82 that will prevent all of those things?
The A10 should be the only option. It's simple.
« The A10 should be the only option. It's simple. » 😳 No. No and no… Nothing can replace the pleasure of driving an atmospheric V8 coupled with a manual transmission. And that's all.
Trap
Alberta
2013 Mustang Boss 302
A set of 4.09 gears would have gone along way to alleviate the mediocre ratios with the D4. My 2020 GT feels like a different car with the 4.09s and the FR Power Kit.
I just went from a 20 GT with PP1, to a 13 Boss 302, the difference in gearing of that 82 is huge, you are right about the 4.09 gears, hell 4.30's might even be better
Dave2013M3
El Segundo,Ca
I would have done 4.30s but the Ford Performance Power Kit ProCal only supports up to 4.09. I have to say though, with the 4.09s and cold weather even with Mich PSS 305/35/19s the traction is dicey.
AlloyPony
Kentucky
2013 GT Premium
100%
Funny that I typed that almost 18 months ago, because looking at the 2025 order guide has me thinking that Ford is in that thought process too. Hmmm.....
The previous Ecoboost did not get the same transmission as the Coyote, different ratios
S650 Mustang MT82-D4 manual transmission in 2024 Mustang - should I be worried? Screenshot 2024-08-26 at 1.32.45 PM
