Steeda Lowered - Sport / Minimum / Dual Rate Springs!
tj@steeda
tj@steeda
2015 Steeda Mustang
More eye candy :)
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 1697066472280
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 1697066485839
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 1697066502288
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 1697066518070
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 1697066532710
TXGT29
TX
Steeda progressive springs with Steeda front camber plates and Steeda 1" spacers all around.
Still trying to confirm best alignment specs to use with this setup, or if I should just go with S550 specs. If anyone can confirm, that would be great.
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 20231022_175400
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 20231022_175415
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 20231022_175437
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 20231022_175453
S650 Mustang Steeda Lowered - Sport / Minimum / Dual Rate Springs! 20231022_175507
TXGT29
TX
Hows the ride quality?
Just fine to me honestly. Not harsh in any way. I'm used to lowered vehicles. Feel like it corners better between springs and wider stance. At least on standard street driving.
timd38
Hudson WI
About how many hours should it take to change the springs out? Thanks!
the 1st spring took me a long time to get done.
All the mechanical stuff was fast and went smooth but the bench work of getting the darn spring compressed enough was a hell of a fight.
The 1st rear spring took me a long time to get out too.
Here are the tips.
after trying to use part store rental compressors I finally just went to harbor freight and spent 100 bucks on their clamshell compressor.
2nd on the rear I had to use a long 2x4 to be able to pry the rear subframe enough.
I did it all by myself but a good friend would be worth the help.
Supra Killer
Huntsville, AL
'16 Ford Fusion, '24 Mustang GT
I'm a little torn between the "min. drop" and the "sport springs". Ideally, I'd like the look of the car to be lower but not obviously 'aftermarket low'. If I didn't know, I'd like to look at it and think "did Ford lower the car like that with the performance pack?"
tj@steeda
tj@steeda
2015 Steeda Mustang
rockstar B
Athens, GA
Can stock non-PP dampers handle the Progressives? I've read some S550 reviews where people said they aren't a good match.
CGNpony86
Louisville, Ky
2010 f150
anyone install minimum drops springs yet?
tj@steeda
tj@steeda
2015 Steeda Mustang
Just looked on our Facebook S650 Page - discussions are continuing on about them. Is there a question you have regarding the minimum drop vs. the Progressives?
highvoltage
NorCal to SoCal
2024 Mustang GT 6spd
where have you seen that? I have seen many running them on FB S650 pages and are happy
